Clearing a cloudy gauge lens
bobmwsc
Post by bobmwsc » 17 Oct 2016, 15:49
So yesterday I was working on one of my projects - a 1989 Bayliner Capri 1750. I have a set of replacement gauges that I scored online a while ago to replace the original gauges. Four of the six original gauges are in terrible shape (maybe 10% transparent) and two of them look brand new. I took out the old ones and set them aside. I need to fabricate adapters to reduce the two largest gauges (speedo and tach) which mount in a 4.25" hole down to 3-3/8" holes for the new gauges.
I was looking at the originals today and wondered if they could be saved. I have a headlight restoration kit that I've used a few times with good success. It's a Turtle Wax Headlight Lens Restorer Kit that I bought a few years back at Walmart for $7 (up to 7.99 now). I tried the rubbing compound that comes in the kit - no luck. I then spent a whopping 5 minutes tops using the sanding sponges then cleaned it off with the included uv protectant wipe and I was very surprised. The gauge is actually usable again! If I spent a little longer I know it would have come out far better. Now I have to decide if I want the new gauges or reinstall the old ones.
Original:
Clear(er):
bobmwsc
Post by bobmwsc » 17 Oct 2016, 16:33
I tried in on the worst condition lens. it's better but not great. The plastic has a bunch of hair line fractures in the surface. I may try again with some fine sandpaper followed up by the headlight kit.
Original:
Clear(er):
overboard
Post by overboard » 17 Oct 2016, 19:52
Wow, huge difference there.
I think I would try to use the original gauges as long as they work, that is unless you want to save them for down the road, then I would install the new ones using an adaptor, new gauges are always nice though!
Your call, as they say 6 of one, half dozen of the other, or maux nix; in other words, either way! :lol:
KMixson
Post by KMixson » 18 Oct 2016, 04:19
If you really want to clean them up use sandpaper and wet sand them down to 2000-3000 grit sandpaper. Then use non-yellowing clearcoat and spray a couple of light coats on them. The lens will look better and better as you put more coats on them.
Al U Minium
Post by Al U Minium » 18 Oct 2016, 07:22
Don't use alcohol on plastic. Some types of plastic develop fractures and cracks. The polishing method looks great.
Post by richg99 » 18 Oct 2016, 19:12
Back in the late '50s, I used to work on some of the old TVs for neighbors.
I found that I could take scratches off of the plastic tube covers by using toothpaste. Just another slightly abrasive compound.
I see that the technology has moved WAYYYY forward now.
Your job looks great. I love to see things restored.
bobmwsc
Re: Clearing a cloudy gauge lens
Post by bobmwsc » 23 Oct 2016, 17:56
overboard wrote:Wow, huge difference there.
Your call, as they say 6 of one, half dozen of the other, or maux nix; in other words, either way! [emoji38]
I'm pretty happy with the outcome. I'm going to use the originals and save the other set (means I don't have to cut the ends and rewire all the gauges).
With about an hour or so of work I went from this:
to this:
Sent from my HTC One_M8 using Tapatalk
Post by fool4fish1226 » 23 Oct 2016, 19:14
Looks great :beer:
Project "A Little Snookered" http://www.tinboats.net/forum/viewtopic ... 21&t=22132
Fishfreek
Post by Fishfreek » 29 Oct 2016, 15:36
Nice JOB!
Fish fear me
Women love me
But I sit here all alone eating peanut butter sandwiches
bobmwsc
Post by bobmwsc » 29 Oct 2016, 23:23
Fishfreek wrote:Nice JOB!
Thanks... I just figured a quick $7 fix was better than shelling out a few hundred and having to rewire all the gauges. They came out better than I expected. I know that when I did my headlights they lasted for close to 2 years before needing a second application being subjected to the New England winters getting pelted with salt and sand. I figure these should last far longer only out in the summer sun and rain (when not covered).
