A different thru-hull-fitting
Houston, TX & Crossville, TN
I just stumbled on this product on a bass fishing site. Don't know when I might need one, but I am happy to know it exists. Looks to be more water-tight than many others that I've seen. richg99
https://www.walmart.com/ip/SeaChoice-17901-Cable-Thru-Hull-Fitting-Black/32739119?wmlspartner=wlpa&selectedSellerId=2132&adid=22222222227021669172&wl0=&wl1=g&wl2=c&wl3=52515983111&wl4=aud-261800281660:pla-84076908071&wl5=9027643&wl6=&wl7=&wl8=&wl9=pla&wl10=113146354&wl11=online&wl12=32739119&wl13=&veh=sem
That looks like a livewell fill inlet. That does NOT look particularly water tight, in my eyes. It could be, if you had a female fitting on one end, and cut it to exactly the right length. I would not use that on the exterior of the boat.
-TH
It's possible that it would be best used to bring a single wire through a bulkhead. I.e. not below the waterline.
I can see a transducer cable, for instance, though I don't know if the opening is wide enough for my t'ducer cable.
This^
