Anyone use Teak Vinyl on casting platform?
Sammy23
SW Michigan
I am new to Tinboat and am looking at converting a 1985 StarCraft deep V 14 footer I picked up for $200. I want to put in a casting deck in the front. Has anyone worked with the teak vinyl flooring? Is it flexible enough to wrap around plywood like carpet is? Thanks!
How much does it cost. This vinyl from cabelas is $15 ft.
Well it depends on who you buy it from. I've seen it at about $30per ft at 8'6" wide. I like the looks of the wood plank pattern. I don't know if it is as flexible to wrap like the material you used is or not? Yours look great!
