I'm changing out the transom transducer and want to install a polymer mounting plate over the old screw holes and mount the new one to it. I'm afraid if I just refill with new screws and silicone it will make the plate bulge. What's the best substance to fill those holes? (only can reach them from the outside)
I was going to just screw the plate to the transom but is epoxy better? I'm afraid with epoxy that I'll never be able to remove the plate if I need to.
Thanks for any help.
