12' vs. 14' v hull
WV1951
TinBoats Supporter
Parkersburg, WV
New to the boards. First post. Didn't see an introduction thread.
Found this site trying to decide on a particular brand and/or size. Glad to see it is a format I am familiar with.
Getting back into a small boat for 10lb. limit water. Small water that wake and wind shouldn't be an issue. Had a 12' fiberglass composite Gamefisher back in the 80's with a 5 hp and small troller. Seemed to work back then.
I have been looking at the same size, but after looking at several on craigslist, etc., I am not sure that I don't want to consider or prefer a 14'. Seems to be more available in a 14'. Two person max. Just for ease of handling and storing is why I thought a 12'.
Pickings are slim this time of year, but probably more negotiable prices.
Did some searching on line and didn't find many opinions or first hand experience between the two lengths.
Anyway, looking for first hand experience for those who have fished both.
What say you that have owned or been in both lengths?. Not too brand selective. The ones that have been treated good should give adequate service. Mostly Starcraft, Mirrocraft, Sea Nymph.
The cleanest specimen I have found is a 12', but it looks so short and fairly shallow gunwales, but it may be the pic angle. Even 14's have different free board. I would be interested in adding a low floor for a flat surface to stand on.
Length is not as important as width. In almost all situations go with the widest boat available to you. It gives more stability and a shallower draft.
I have an Alumacraft 1448 with a front casting deck over the benches, I can stand on the very edge and the gunwales are still 6" above the water. It's very stable for a small boat. I've been in some narrower boats and walking or moving around in them needs to be done with care.
14s can be had in narrow river boats or wide, tall skiffs that are capable of handling some rough water. 42-48" widths are fairly common, but they can be found skinnier or wider.
For 12s, 36" is a pretty common width.
You won't find many people that wish they would've bought a smaller boat.....
For an adult I'd say 14'. Had a 12' as a kid myself, it's a great starter boat but adults (responsible ones) bring more gear and equipment on board, we tend to be 40 pounds or more heavier too.
Nothing wrong with 12' boats, probably the most popular size we use in Australia. If it wide and a little flat then stability will be the sane as sny big boat but you can getcaway with smaller motors and they are lighter and easier to handle.
I prefer 11ft boats myself as they are so light to handle and fly along in a small motor, but most importantly they get into tight spots that you can't get into withva bigger boat.
The one in the photo looks pretty standard, stability should be fairly good, tge 6hp should move it ok, although its probably a tad under powered, I'd rather an 8hp as a minimum, but if you have power restrictions then it should be fine.
Don't ever think bigger is better, sometimes and that can be quite often a 12' boat can be perfect for the fishing you want to do.
We do a lot of car topping here and you very rarely ever see anything over 12' and has helped our love of 12' tinny's become what it is today.
All things being equal, go for the 14'. But if the 12 meets your needs better, then no reason you shouldn't go for it.
I've fished out of Gamefishers way back when. Might have been in the late 70' or early 80's. If I were still young & agile I would' have a problem, but unfortunately, neither of those attributes applies to me any more. :D
12 is ok if you're going to fish alone... if you plan on bringing another human I think you'll appreciate the room and increased stability of a 14...
Appreciate the input. Pretty much confirmed to where I was leaning. Here a couple of candidates, if I want to drive a ways and they are still available when I decide. Looks like 14' is the way to go.
1973 Starcraft, 1999 9.9hp Yamaha $1300
1977 Mirrocraft, 6hp Evinrude $1000
If you can, bring all the gear you would normally have with you and a buddy, then climb aboard and see how cramped/roomy it is. Make sure you have a cooler, gas tank, tackle box or two, rods, oars, battery and a trolling motor if you plan on having one.
I know it's sold, but an 8 HP even on a 12' is OK for 1 person, but I'd want at min. a 9.9 for riding 2 adults. 15 would be a nicer option all the way up to a 25, but then your getting less and less portable.
WV1951 said:
Strictly 10hp or less water.
Get a 15 that has the same cowling as a 9.9 and swap out the cowling. You get 5 extra horses and the cover says 9.9.
Or grab a 9.9 and have the 15 hp conversion done to it.
I've had a number of 11ft boats, always with 8hp outboards, they absolutely hammer if your on your own, but with two people a 10hp is a much better option.
The 8hp did fine in lakes but in rivers or strong ocean currents it could struggle to get on the plane.
I would definitely get a 10hp on a 12ft as a minimum, up to 15hp if it is rated.
My current 11ft is rated at a 10hp but the 8hp does it fine, although I haven't had two people in it yet.
And most of the places I go I'm limited to 20 knots max speed anyway.
We have lost my original question. This is typical of forum discussions. I am not concerned about getting on plane or going from point a to b fast.
Will a 12' provide adequate space for two people if the seating is spaced properly? Is there a lot of difference between a 12 and 14 for those that have been in both?
Forums topics do go off on tangents, sorry for that.
But to answer your last question theres plenty of room for two people to fish comfortably on a 12ft boat.
I have plenty of room on my 11ft boat for two people, but a 12 us definitely more comfortable with two and more stable.
Have no fear about taking two people on a 12ft boat, and even a 3rd in a pinch, but that can get tight.
WV1951 said:
Thanks, Bob
BTW, with your avatar, are ya bloomin' nuts mate? Cheers.
What that little thing, you should see some of the ones we couldn't get out of the water. :LOL2:
But still got in to remove the hook.
But if you want an Idea of two grown men fishing out of an 11ft tinny that isnt as stable as a 12ft tinny. Then he is a mate in my old tinny with a fish I hooked for him because he said hes never caught anything big before. :lol:
https://youtube.com/watch?v=1N-yBhtUKMI
Think I have decided on a 12'. May have to move front or rear bench to maximize distance between front and rear passenger, if not already where I want them. Gear will be minimal. When I go alone, it will be easier to handle, put in and take out. Also will be able to go smaller motor. May have one cornered near Columbus, but will have to see.
My previous boat from many years ago was 22 ½’ with a lot of bells and whistles. When I was shopping for my current boat my objective was something open, light, simple, easy to handle and definitely smaller. The added feature I really wanted was remote steering. I looked at 15’, 16’, and 18’ open boats. I ended up with a 15’ boat with limited storage. Fact is most of my “storage” needs can be accomplished by tossing in an old backpack or two. Sure there are some times I wish I had the 18’ version of my boat, but after a coupe of years I still think I made the correct decision going for the smaller boat. And besides, fish can't tell the difference.
Anyway, sounds like you thought it through. Enjoy.
I had a 14ft and I liked it a lot, it was a 20 inch transom, I would not own a boat that was a 15 inch transom. Never thought it was too big regardless of where I
fished. Should go into any garage ok. Very lightweight, less than 1000 pounds total package. I towed mine with the corolla and it pulled fine. My experience with a 12 footer
is I wanted something bigger.
Bob9863 said:
WV1951 said:
Thanks, Bob
