Wire and transducer cable plugs. See photo..
10sne1
what are these called and where can I buy them? The white plugs where transducer wire passes thru to below deck? See photo.
Its a Grommet. Look online,, Ebay Amazon or try auto stores. Harbor freight might even carry Grommet kits.
Is this what you are looking for?
https://www.amazon.com/s/?ie=UTF8&keywords=seachoice+cable+thru+hull+fitting&tag=googhydr-20&index=aps&hvadid=228968656293&hvpos=1t1&hvnetw=g&hvrand=1738068996942394588&hvpone=&hvptwo=&hvqmt=e&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9020145&hvtargid=kwd-327655034373&ref=pd_sl_72y4qdk567_e_p37
Thanks fishitlite, that does not allow power and transducer cable fit, with customizing it, per a review on Amazon. Looking for simple product that will receive both wires? Looking into grommets per jake, but no luck yet.
Electronics supply stores like Frys may have what you want. Even Lowes has some in those tall cabinets with many drawers. Ace hardware stores used to have some similar cabinets with odd items in them.
Worse case, make your own with some silicone in a PVC Pipe mold.
rich
