Aftermarket power trim with manual tilt?
Blake
Nunya, Tx
I thought I read somewhere that a lot of guys take the factory manual tilt off outboards after they add an aftermarket power trim like the cmc unit. Basically letting the motor swing freely, enabling them to pop over logs and the motor will slide over the log but still fall back in to place once clear. Do any of you guys set your motors up this way? How tough is it to use reverse?
