boatlose
Hello everyone.
I'm rebuilding the transom on my 15' Welded Gregor H-51. The transom that was in it has the factory specs on it, where there are two ratings. One for max horsepower of 15, the one below it says 7 max hp.
That can't be right, can it? That's not saying 15 is the max for center console controlled outboard and 7 for tiller is it? It doesn't make sense that this boat would be rated so low. My older 13.5' riveted valco has the same hull shape but is rated for 20hp max.
