Filling the gap. tracker hatches
reelfunnm said:
After removing the carpet I have found there is a large gap between lid and frame. I will be laying down vinyl, which wont take up enough gap. Any suggestion.
I did this years ago. Aluminum angle rivet around the edge of the lid. To fill in the gap. With the one side of the angle on the bottom. And you can adjust the height also. So the lid will flush better with the deck. So it makes like a picture frame on the bottom, inside of the hatch. Then you can even put gasket around. For better sealing.
