Best glue to use to fix vinyl flooring
ErnieLearns
The factory installed vjnyl flooring is starting to peel upwards at a seam. It is not a large problem, but what is the best way to glue it down? Superglue, gorilla glue, or something else?
Problem is caused by getting wet, drying out and repeating, which causes the edge to curl. I was able to fix a few small spots by using a small tube of vinyl cement, bought at a marine store. It is clear in color and can also be used to patch small holes or tears.
On one larger area, whereas I didn't want any water intrusion to get below, I put a length of rubber 'door threshold' piece to seal it off, well gooped/sealed with LifeCaulk by BoatLife (comparable to 3M 5200, but less expen$ive to buy and the tube lasts 2-3X longer).
