Wvhunteradkins
I have a 17 ft ouachita jon with foam filled sides that is leaking from somewhere and I can not find out where. The leak is not so bad that I can not use the boat But I have to run the bilge for about three minutes once an hour. I was wondering if there was something I could paint the boat with to help my leak problem. The boat could use a paint job anyhow. Thanks in advance
