Well ... in your case - 'maybe'.10point said:I assume that's the sign of needing a new transom?
You must be referring to that brown piece. That is not part of the transom. I thought that might be confusingCedarRiverScooter said:Maybe you just need a new 2x4
DaleH said:I don't know who put that wood in there, but they oriented the grain of the wood the WRONG way, as the strength from plywood sheets, from bending, is when the grain runs the long way across the hull, from side to side.
Well, NOT when you cut it that thin (height) it doesn’t. Try it for yourself ...ppine said:Plywood always has plies oriented in different directions. The way the grain runs on the outside ply has nothing to do with the other plies.
