Mount/anchor cooler and other items without drilling holes
uttexas
Supplies
PVC board at HD or Lowes $7 for 8ft. Cut with saw to desired length
Lexel sealant/adhesive $8
Handles screwed into PVC board. $2.50 Walmart hardware dept
Short Ratchet straps
uttexas said:
Supplies
Did you remove the deck paint / coating before applying the adhesive?
I cleaned the area and the pvc board with isopropyl alcohol. Sanded the bottom of the pvc board with 100 grit and the deck under the pvc board. Cleaned again with isopropyl
Weighed down the pvc board with anchors as the Lexel cured
Takes about 5 days for Lexel to fully cure in the summer
That PVC board isn’t going anywhere—Lexel, once cured, adheres just as well as PL 5200, but much easier to remove in the future. It’s much more manageable and friendly to work with compared to 5200. Paints over well also.
Nice!
I did that around my battery box. It was jumping all around when going down the road.
RiverLife said:
Nice!
Did this work well for that battery? Batteries are, heavy...
CMOS
Further modifications
Closed cell foam flooring cut to size, enveloped tightly in reflectix, taped with aluminized HVAC tape, Lexeled to underside of lid
Weather stripping/window seal inner lip of cooler
More closed cell foam Lexeled to outside of cooler for hook/lure hanging/storage
Rod holders screwed into PVC board and Lexeled to outside of cooler
Closed cell foam, non slip kitchen/bath mat Lexeled to lid for standing/sitting
