FWIW ... I had the components, but just wanted new panels to set off the new wiring scheme on my new boat. This site here makes custom sized switch/breaker panels, all the way up to truly custom ones with your boat brand or hull name laser etched into the panel and the switches can be backlit!
I had them make up a custom panel to hold my Bennett ATP auto-trim tab switch and 2 accessory plugs, a 12V power socket and a dual-port USB charger. Custom made to my size and finish it was only $37. https://newwiremarine.com/product/e-panel-builder/
They are also can excellent source for laser etched BACKLIT (in white, blue or red) Carling Contura switches, where each switch (less those only momentary) have 2 indicator lamps per switch. One provides the backlight whenever the Nav lights or helm lights are on, whilst the other illuminates whenever that circuit is energized.
