bikerider said:
I neglected to mention in my first post that it would not be stood on to cast but used as a step for people and dogs to get into the boat more easily, and provide a bit of covered storage.
It can be done, and I would Do the same for storage purposes.
What you need is a way to fasten the deck right at the bow, probably near the hardware for the u bolt for the winch pull ( if it has one).
To avoid drilling holes in the hull I would get some good epoxy and glue some aluminum angle iron about 8-10" down each side from the bow, the build off that to the bench with 1/2" plywood.
When you do your hatch door, make sure it's very strong supported underneath.. I made the mistake of only doing minimal support and then someone fell through after it was stepped on a few times.
Sent from my SM-G903W using Tapatalk
