16-foot Lund needs interior redone - advice please.
stickball
Hi Everyone -
I have a 1998 16-foot Lund that is getting kinda beat inside. I'm probably the third owner. Interior is carpeted. I have a cover for the boat, but use the boat regularly (several times a week, all year...) and so don't cover it. It lives outside. One of the rear hatch covers has a broken hinge and consequently doesn't fully close properly. My biggest concern is that none of the hatches are dry. I live in the Pacific Northwest where it rains a bit, and would like to redo the inside of the boat to allow for dry storage. Bow is wired for electric trolling motor. There's a bilge pump on a toggle switch, and the port side has a good live-well with aerator.
I've posted a couple of wide-shots from when I bought the boat a couple of years ago. There's a different main motor on there now, and I removed the bimini top. I could sure use some of your collective expertise and suggestions. Thanks so much!!
3M makes adhesive backed weatherstripping that's used on pickup truck tool boxes for sealing out the elements. I have a big roll of it. Google it. It's a peel and stick type application. A industry that uses it is the trailer industry, so if you have a enclosed trailer manufacturer near you they probably have it also.
One other suggestion. Put your bilge pump on a float switch instead of a toggle. That way if it gets a lot of water in it it will pump it out when unattended.
autobody shop supply store will sell it
