14ft Welded Jon
jtf
2
14ft Welded Jon
Post by jtf »
Thinking of building a smaller 1442 or even a 1436 boat when my 1648 jet sells. Reason is that it's hard to put-in a wider boat on my home rivers. Very rocky areas need a smaller hull to access. Would prefer a mod/vee and small jet. Welded would suit.
jtf
2
14ft Welded Jon
Post by jtf »
Only one I can find is Weld-Craft? Want a mod-vee.
LDUBS
3
14ft Welded Jon
Post by LDUBS »
If I even understand the difference, I would suspect most small utility type boats are going to be semi-V's. Not much help I'm afraid.
Have Rod - Will Fish
LDUBS
3
14ft Welded Jon
Post by LDUBS »
Klamath's 14' is a mod-V (Klamathboats.com). Northern California manufacturer so I'm not sure they would be available in your neck of the woods.
jtf
2
14ft Welded Jon
Post by jtf »
Mod-Vee vs flat bottom
ruffhunter
14ft Welded Jon
Post by ruffhunter »
Alweld or Weldbilt. Weldbilt will be cheaper. Theyll make you anything .80/.100 gauge. Check out backwoodslanding .com upper left corner click on boat sizes and look at all the photos. I would get the 1442. I was going to get a weldbilt recently but found a new leftover alweld 1242 mod v dirt cheap.
turbotodd
14ft Welded Jon
Post by turbotodd »
I looked at Weld-Bilt when I was boat shopping. One of a few things I didn't like was how BIG the ribs are. Gives me some more ways to get tripped up while moving from front to back or even side to side. They're really tall. If I were to put a floor in it, the height of the ribs would have put the floor 6" above the bottom of the boat which reduces the amount of space inside as well as moving the boat's center of gravity (whether that makes any difference or not I do not know). Also the one I was looking at (1448 MV) had 7 strakes on the hull. 5 is plenty. 7 is going to be slightly more stable but will also slow the boat down some, not that I'm "that" concerned about speed but it was just another reason for me not to consider them. They are built ok, not great, but not bad either. Some of the welding was questionable which is not unusual of a mass-produced boat. Also the one I looked at did not have a horsepower rating; was a commercial rating meaning no floatation.
WINGO-LINGO
14ft Welded Jon
Post by WINGO-LINGO »
i LOVE MY 1436 for duck hunting. Less is more.
onthewater102
6
14ft Welded Jon
Post by onthewater102 »
I'd go with the 1442 over the 1436 if you're trying to get in tight places - the extra displacement won't come with much extra weight so you'll ride shallower in the water. 6" shouldn't make a difference navigating tight areas, but welded boats are considerably heavier than riveted ones as they require much thicker material.
2002 Alumacraft 1436LT w/ 1984 Mariner Tiller Converted to Remote & 55# Minn Kota Terrova 12v (removable)
