Transom Material
MrGiggles
2
Transom Material
Post by MrGiggles »
I apologize, I'm sure this has been rehashed many times here, but I'm having trouble deciding.
I pulled the transom out of my 17' Tracker, it was well overdue. It is right at 1 1/4" thick, so two pieces of 5/8 ply sandwhiched together should be just about perfect.
The closest Menards does have some marine ply in stock, but only in 3/4", which will not work. 5/8 is special order and will take more than a week to arrive.
Otherwise, they have regular CDX sheathing and BCX sanded in 5/8. Would either of these work?
Additionally, what is the best coating to apply before I drop it in?
CedarRiverScooter
5
Transom Material
Post by CedarRiverScooter »
Exterior has the same glue as marine. The difference is that marine has no voids. I assume BCX has less voids than CDX, so that would be my choice, assuming it is in budget.
There is more than 1 way to waterproof it. Epoxy coatings, Old timers formula, paint. Do some reading. Chances are it will outlast your ownership with any of the methods.
MrGiggles
2
Transom Material
Post by MrGiggles »
CedarRiverScooter wrote:
25 Jan 2020, 21:49
BCX is only marginally more expensive than CDX, and less than half the price of marine.
Dennis8269
3
Transom Material
Post by Dennis8269 »
In regards of coating it. I am working on a Tracker v17 and used Coat It. The stuff is amazing not only waterproofs it but also strengthens the wood .
I coated the underside of all the wood in my boat and transom with it.
