DaleH said:To help also achieve a 'mechanical' bond I use a keyway cutter in a router ( cutting tip shaped liked this "/_\" ) to mill some slots in the back of the poly board.
One can use a drill, just drill holes into poly board, but not through it ... at various angles all over and leave the holes or edges 'rough' inside, gives the goop something to stick to. Make sure to goop those well 1st before adhering, so the goop on the hull mates with it.Bradh said:Yeah I was reading that. I don’t have a router but I was going to do what I could with a dremel. Thanks
Bradh said:DaleH said:To help also achieve a 'mechanical' bond I use a keyway cutter in a router ( cutting tip shaped liked this "/_\" ) to mill some slots in the back of the poly board.
