Millennial B100 boat seats
Joemac4445
, Muscatine Iowa
Does anybody use or have these Millennial B100 boat seats. I would just like to use a swivel mount directly attached to my aluminum boat seats I'm not sure if it works only with a pedestal mount can anybody verify this?
Yep, great seat, I have the marine version and bolted to an Atwood non-locking swivel, bolted directly to boat bench seat. Wife is checking for pics, and will post if she finds any. Works great and can use it at the helm of a tiller steered boat only.
I put 2 of these seats in my mirrocraft. They’re mounted on pin swivels. I did lower the bench they’re mounted on, so I was sitting at the same height. Also, the pin mounts I used had a 7 degree angle tilting toward the rear. There is also a rearward tilt built into the millennium seats. I thought at first it would be too much, like I was reclining. It ended up being super comfortable. I like the seats a lot.
