Folks,
So the issue that I am having is that. I have sealed the boat with a decent quality polyurethane sealant, primed, painted and completed the bottom of boat. I am having water infiltrate into the boat through the seam skids on the bottom of the boat. See pictures attached. I sealed the boat rivets, seams and everything inside the boat however due to no access under the bench seats was not able to seal those seams, rivets.
My question. Is it possible to drill a hole at either end of the seam skids and pump in a waterproof expandable foam to seal these skids and seams?
