Second boat, added 2 feet!
Boating related questions, small projects, custom work and talk go here.
SomethingIsFishy
2
Post by SomethingIsFishy »
Picked this up yesterday because I decided my 10’ Jon boat wasn’t big enough…
I need a trailer, and I’m not sure what the motor needs… previous owner put a fuel pump on it to convert it from a pressurized tank… he said he got it to run, but it didn’t run very well… I’ve got almost 20 years experience as an automotive mechanic so I’m sure I can get it going (unless there’s something catastrophic wrong)…
I’ll post updates (and probably a lot of questions about the motor) as I work on it…
SomethingIsFishy
2
Found a trailer!
SomethingIsFishy
2
Messed around with the motor a little tonight, wanted to see if I could get it to make some noise… it has spark and compression but I couldn’t get it to fire… looks like I’m going into the carburetor…
SomethingIsFishy
2
It runs, and the water pump works! I’m gonna need a new gasket for the sediment bowl (water separator?), it leaks a little…
SomethingIsFishy
2
Took the boat out the other day with the trolling motor… (electric-only river). We had fun, and the boat did well!
Still need a few minor things for the evinrude… the previous owner has to dig the fuel tank out of his shed, and I will have to get fuel lines. I’ve also got to change the oil in the lower unit and I’m seriously considering just replacing the impeller as a precaution even though it pumps water just fine…
SomethingIsFishy
2
Guess what I get to do! Since I’m going in to do the seals I’m obviously going to do the water pump while I’m in there…
Edit- magic oil/water mix flows sideways. No idea why my pics randomly post sideways…
CedarRiverScooter
6
Post by CedarRiverScooter »
Make sure & replace shift rod oring too. That was the hardest one to do, I had to drive it out with a punch.
SomethingIsFishy
2
Thanks! I might not have thought of the shift rod o ring…
SomethingIsFishy
2
Any recommendations on where to get parts for the evinrude? Thanks!
CedarRiverScooter
6
I have had good response from Marineengines.com. Their online parts catalogs are a big help in figuring out what you need. You might be able to find it cheaper elsewhere, but they may not have the same level of service.
