wo show
Well, I'm a new guy on here and was going to start modding my 14' Aerocraft,( https://www.tinboats.net/forum/viewtopic.php?f=13&t=5498)and after much thought, I decided it wasn't going to be a good platform for what I wanted. So, I sold that and found a 14' MirroCraft that is much wider and built much better than the other boat so I jumped on it. It needs a little work but what older boat doesn't.
I also found a nice 4 hp Johnson motor that was in great shape to put on the boat. I was driving it home, and I called my buddy to tell him about it. He wanted to see it so I drove it over to house. He saw it, and wanted it. He traded my a MINT 7 1/2 Merc with electric start. He wanted something smaller for his boat that he cartops. So that will be going on the boat when its done.
I also picked up a trailer from another CT site that I belong to. I looked at the trailer in the dark and paid for it. The guy brough it over my house when I was at work. It turned out not to be as nice as I though, but I'll make it work.
Oh yeah, along with all this, I ran across a 10' Lowe Jon Boat I just couldn't pass up. That will be a project for later.
So, I finally got a little time this weekend and did a little work. First I cleaned out the garage so I would be able to fit the boat and trailer in and be able to work on it. I took out the seats and inspected them. The foam under the seats is a little beat up, I'll re-foam later. I rough sanded most of the inside until I ran out of pads for the sander. I also sanded a little on the outside to see what I'm up against. My plan is to try and do a little sanding each day. I want to get the boat painted before I do anything to the trailer, this way I don't need to worry about scratching it or getting any chemicals on it if I use any. I'll keep updating here as I go. Thanks again for a great site!
Here are some pics:.
