Simple leak help!
baptistpreach
Oklahoma
I found what I thought was a veerryyy slow leak. Thankfully, its not the bottom of the boat, but where the bolts for the transom are. I noticed every time water splashes those spots that there are bolts, I can see a little water trickle down. How do I fix it? Thanks!
ben2go said:
Take the bolts out and add 3M 5200 marine sealant around the holes.It can be purchased at box mart and home improvement centers.
bingo, just make sure its not a bolt you ever need to take out again. You know its strong stuff when the recommended usage is securing decking down. I call it "white death" because once it sets up you cant get it off.
