On the underside of my boat where the knee brace on the transom is riveted...it leaks a little bit. This is due to me replacing the transom and having to flex the brace a few times to get the new transom boards in the back. What is a good quality fix to put on these rivets to stop the leaking without re-riveting them? The brace is solid into place because its up against the new transom, but I wanted to seal the bottom.
thanks
thanks
