Storage boxs the size of large coolers
dunk50
South Bend, In
I have looked at about a hundred hours worth of mods. I have not found what I am looking for. I have a Tracker 1754 with 8 1/2 feet between front and rear seat. I am looking for a couple of large boxes say 3' by 18" by 18". I had planned on using large coolers but after taking a closer look found you loose a lot of storage do to the cooler walls being so thick. Don't need the cooling effect just the storage. Also I want to use them for seats so they have to be fairly strong. Anybody have a suggestion other than building my own. Thanks
You can try something like this. https://tinyurl.com/7qqqwj
I have seen these at Walmart and Home Depot in different sizes.
those are about the same as coolers as far as the sides taking up space.. they are somewhat durable, but the sun does get to them after a little while and they warp unlike coolers
You know how to work with aluminum or wood? Build some. Make them exactly the size you need, and coat them with carpet, or a truck bed coating.
This place has all kinds of jon boat accessories but kind of pricey.
Take an idea and build it urself or maybe you know someone that can do it for you.
https://www.gatortraxboats.com/Accessories.htm
A little larger than your dimensions but maybe... Plus they have other sizes too.
https://www.target.com/Suncast-Deck-Box-Seat-Wheels/dp/B000357GJK/qid=1232110652/ref=br_1_1/176-9881277-7900162?ie=UTF8&node=304850011&frombrowse=1&rh=&page=1
