old_boat_new_smile
I just bought a late 70s era 12' flat bottom.
I leak checked it last night (filled it with water on saw horses) and I found three slow rivet leaks and the drain hole leaked fast (yes I had the plug in).
Here are the questions.
1. Is there something better for me to use than drilling out the rivets and replacing them or should I stick to a marine rivet and just replace the three?
2. Do I need a drain hole, it seems to be bent up a bit which is causing the plug not to seal. Should I permanently seal it, or is it better to keep it?
I appreciate any answers.
