1542 Fisher
partimesquid
Hey Ya'll,
I stumbled on to this forum and.....WOW, a lot of good info!
I will post starting pics of my project this evening. I wanted to ask a quick question since I just dropped $50 and change on two pices of pressure treated plywood. I gather from reading the post here that pressure treated wood and aluminum don't mix.....Dohhhh!
Well, how about if I glue some linolium or other thin rubberish product to the plywood before I toggle it down to the seats?
As long as the wood is not in direct contact with the aluminum you will be fine.I would use something like carpet strips that would allow water to evaporate from the wood when it gets wet.
Keep in mind too, there is nothing that warps worse than pressure treated plywood. May not be best to work with, even if you don't let it contact the aluminum.
