lckstckn2smknbrls
- Joined
- Oct 5, 2008
- Messages
- 4,855
- Reaction score
- 177
- LOCATION
- Lake in the Hills Illinois
I have a 14" Jon on a small trailer with a 25hp motor. Is there a way to weigh this using a bathroom scale?
Popeye said:Can you weigh it with a bathroom scale? Now that depends. Most bathroom scales can weigh objects up to 300 pounds. That means you can weigh up to 600 pounds using that scale. Place a solid block (the same height as the scale) near the scale and place a board from the block to the scale and zero the scale. Weigh the object half way between the scale and the block and then double the reading on the scale. That's the way we used to weigh a garage door if it was over 300 pounds.
