sirslurpee
I'm working on my grandfather's 14' semi-v.. (I forget the specifics of make/model. It's close to 60 years old though.) ..and I'm considering trying to convince him to buy the materials and let me deck the boat and install semi-elevated seats :twisted:
Right now he's really concerned about the project "That's gonna cost way more than the boat is even worth!"
I'm trying to go along the lines of "I'm unemployed and need something to keep me sane, and, you've gotten a lifetime of use out of this boat so if we put a little cash into it, maybe I can get a lifetime of use out of it too"
So I'm curious to know if anyone can help me out here. Maybe some figures from similar projects (and pictures too?)
Also, the middle and rear seats are riveted down, and there's no way to access the underside of them. I will take some pictures in a bit to show what I mean. I am concerned that it may be an issue with the project. A few of the boats I've seen on here have wood benches, that are just bolted to brackets riveted to the gunwhale and there is free space underneath. Should I even be concerned about the benches if I'm going to deck it?
Lastly, the one thing that boat absolutely NEEDS is a drain plug. I store the hull outside (for now) and it's a PITA to bail it out every time it rains. Is there an aluminum fitting I can buy and just drill the transom and have someone weld it in place?
