nicdicarlo
Does anyone know if they sell Marine Grade Plywood at the HomeDepot/Lowes? If not, does anyone know a good substitute or a place that carries it? I would be looking for 3/4". Thanks.
...I would recommend getting the higher grade (has footballs only on the outside ply) exterior grade ply from lowes, and giving it a good coat of oil based paint on all sides, ESPECIALLY THE EDGES.
With composites, there is no need for a ply, as it can be formed into whatever shape. Plywood is make from thin plys, that were actually curved around the tree. I mean, the wood was basically unrolled, then flattened, and glued together, with the grain going the opposite way. They can't unroll a 3/4 inch piece, so they have to glue many together. Composites can be made however thick they want.pbw said:Isn't there a composite plywood out now days?
Marine ply is not pressure treated. It is regular ply, made with a better species of wood. Also, there are a lot more thinner plys. Also, all the knots, and voids have the little footballs in them. Not just the top ply, like the better grade HD ply.micropterus said:Pressure treated and marine grade plywood is corrosive to aluminum. You have to be careful that there is no direct contact between that kind of wood and bare aluminum.
bassboy1 said:Marine ply is not pressure treated. It is regular ply, made with a better species of wood. Also, there are a lot more thinner plys. Also, all the knots, and voids have the little footballs in them. Not just the top ply, like the better grade HD ply.micropterus said:Pressure treated and marine grade plywood is corrosive to aluminum. You have to be careful that there is no direct contact between that kind of wood and bare aluminum.
Waterwings said:What if you used some decent Exterior grade ply, and then coated it with some good exterior oil-based sealant?
