beggining to mod my 12 foot ouachita
yankyfan100
Westchester NY
Hey everyone, i stumbled across this sight when i was looking into how to fix leaky rivets. Now i decided to give her a paint job and possibly mod it a little.
So far i got 3 comfy seats seats, 2 of which on removable stands, and a rod holder. My motor guide 45lb varimax just came in today also. Im thinking of doing a little front deck for storage and stuff..but we will see.
after fixing the rivits im coating the floor with a product called multifunction protective coating. My dad got it for coating a stone floor but it can also be used on metal and is a very tough product. After that im painting it red.
here she is, all stripped down and getting ready to sand it. She is a 12 foot ouachita..got her for free so cant complain!
pics of it painted soon to come
Sand that down real well, prime, and paint. Will look great. Also, I'd replace the transom and keep the decks low.
Nice boat. You'll be VERY happy with the varimax. I have the same one, and it pushes my 14 footer quite well. its great on battery life, and completely weedless. Only complaint is the handle is made of plastic, so when its extended it feels a bit flimsy. But overall, its BY FAR the best TM for your money on the market. Good choice.
What type of paint are you using for the boat? Do a few searches and you'll find a ton of information on painting. Its better to do it the right way the first time out, instead of having to strip it down and repaint it again in a few years.
Good luck, and keep the pics coming!
Good call on the primer, but I'm not sure about the paint. It will probably be alright, but I was shooting the breeze with the painter at my uncles collision shop and he said to stay away from auto paints for boats. Mostly because they dry very hard, which leads to cracking when the boat flexes (and jon boats flex a ton) and they often times end up with blisters.
You might be better off going with a topside paint. You can find it pretty cheap online. I ordered from here https://www.wholesalemarine.com/p/PET-3106Q/Easypoxy+High+Gloss+Paint.html and it was a pretty good deal, plus shipping took only one day.
thanks for the advice..anyone else have any input on using the automotive spraypaint? would a quart of that other paint be enough to paint only the sides of the boat inside and out, the benches, and about 4 other square feet?
I don't think I would recommend the spray paint because you don't get much paint on the hull per can. Coverage is usually about 3/4 of what the can recommends for me so double your order and do two coats where it's going to rub.
Jamie
I'd also go with a quality topside paint like Pettit or Interlux - they are more forgiving as mentioned. They can also be thinned, sprayed, or rolled.
after looking at your first picture, i'd suggest moving the bench seat to the rear, and putting the fireplace in the bow, better weight distribution.
I knew a guy who painted his Jon with tractor paint. It's a hard enamel and is also flexible. I haven't talk to him much, since I used to work with him, to see how it was holding up. I will try and get a hold of him to see how it's going and let you know.
Tractor paint works well,but it takes a few days to cure.
I did the paint today. 2 coats of primer then 3 +1 light coat of the duplicolor car spraypaint. i decided to go this route becuase my boats get a beating every year and get lots of scratches so with spraypaint i cant make quick fixes. I have a feeling it is going to work out well. I also painted some seat stands white along with wooden tops for the benchs to place the stands on. Im thinking of doing the inside of the boat white..but i dont know how i feel about the red white and blue theme..any thoughts?
**For the inside, if i can i would like to try and use something i can brush on. It is primed. i was wondering if rustoleum would work for the interior (in terms of it adhering to the primer). Rustuleum has always given me great results on other projects and seems to be very durable.
I really like that shade of red on my monitor it looks kinda burgundy... correct? Personally I would stay away from the rwb color scheme. Not that I'm not patriotic. Just seems a little corny to me. White on the inside may be a little too bright on a sunny day.
I don't know which I like better.....The paint job, or the balancing act :lol:
Yeah..im going to stay away from the rwb..very corny.
I will prob do navy blue on the inside or grey (thanks for that idea)
the color is actually duplicolor automotive red, but it does somewhat look like burgundy. i really like the paint..it has somewhat of a sparkle or particles in it that make it pop. i am going to coat the boat in a multipurpose clear sealer that is incredible durable. i tested it on one spot ontop of the red and it looks awesome..really brings out the color. i wish i could paint more but a lot of crappy weather is on the way :x
and the balancing act kinda pieced its way together in order to get the right height for me to paint it..i wasnt trying to be ridiculous hah
