cyberflexx
If you have read my other post in the boats forum you all would know that I purchased a 1988 Alumacraft 1457 with a 1985 (brand unknown) trailer. I gave $800 for the boat and hopefully I can start on the conversion this week, weather and friend's help permitting.
Here is what I have purchased so far for my boat conversion.
2 new 12inch Tires
Trailer Light Kit
TH Marine Mini Jacker JackPlate
Livewell Airator
12 volt main on/off switch
12volt 4 rocker switch power center
2 12volt lighter sockets
12volt Battery onboard Batt. Tester
2 grey WISE brand bass seats
2 seat post floor mounts
2 seat post pedestal adapter
1 seat post ( I have another one already)
Trolling motor plug and socket
3 – 8 foot 1/8x1inch Aluminum Angle
3 – 3foot 1/8x1inch Aluminum Angle
Riveter and Rivets
Bolts/Nuts and Washers for the alum. Angle
6 2inch hinges for storage box lids
2 larger hinges for the back deck access panel lid ( to get to batt and fuel area)
Fire Extinguisher
Whistle
Battery Box
Marine grade caulking
JB Weld
Black Rustoleum spray paint
Winch strap since the current one is a rope
This is what is needed…
2 new 1 inch plugs ( the plugs I bought didn’t fit as I got them from HarborFrieght)
1 Depth Finder
Some red and black wiring to wire up everything
5/8 or ¾ Marine grade plywood, lowes has something called Avantex that is $22 a sheet will need 2 sheets probably
15/32 plywood, watersealed too.. for sidewalls.
LCD Digital clock to add to the power distribution center
Marine carpet and glue
TIME TIME TIME
2 new 12inch Tires
Trailer Light Kit
Livewell Airator
Riveter and Rivets
Fire Extinguisher
Whistle
Battery Box
JB Weld
1 Depth Finder
TIME TIME TIME
