Wildman
Disclaimer:
I am a redneck that has an idea from time to time. My ideas sometimes work, and sometimes they don't. Do not attempt any of my ideas as authority or you might find I am full of it most times
_________________________________________________________________________________
So, the idea was how to bond two pieces of aluminum. Most would say it can't be done. Well, I think I almost have figured out how to do it. So far, the two pop rivets and a Magical Wildman Mix (half JB Weld and half two part locktight metal/wood 5 minute expoxy) seems to be working.
These two pieces are bonded together flat surface to flat surface and I can not get it to fail by hand; by the view of the joints it didn't even crack with a lot of hand pressure pushing and pulling on the angles. I put some mix in between the two pieces and clamped them together. I am letting it go over night and I will put it in a vise and see how much pressure I can put on it until it fails. But, once I join two pieces with proper ears, cut and places rivets on 4 points on a joint and bonded with my Magical Wildman Mix I think I have answered the question. How do you bond two pieces of aluminum so it is structurally strong? Put some Magical Wildman Mix on it!
