elopomorph
- Joined
- Aug 3, 2009
- Messages
- 9
- Reaction score
- 0
I have looked at several of the boat modifications and the work is very impressive. Every modification that I looked at used wood and plywood. However, in Florida the theme is wood=rotting. Why do you guys use wood and plywood instead of foam board or some other synthetic material? Don't you guys have rotting problems with your wood modifications? I don't think I would use wood because I think the humitity alone in south Florida would cause the wood to rot.
