It is currently 23 Apr 2019, 00:30
SwampRunner
 Page 1 of 1 [ 7 posts ]
 Post subject: Old crystialized gas
PostPosted: 12 Apr 2019, 16:42
Old crusty gas in the bottom of a steel OMC tank. Anyone know of a good way to clean it out. Its gummy and kind of soft. Tried to leave a mix of fresh gas and oil mix in it over the winter and that seemed to soften it a bit but still stuck in a lot of it. Tank is in good shape other than that as in no rust inside or out. Is there something that would dissolve it? Thinking a can of Sea Foam or maybe some of that stuff used to soak carb in?
PostPosted: 12 Apr 2019, 18:37
Place some pea gravel in it and shake vigorously. That will break up the deposits in it.
 Post subject: Re: Old crystialized gas
PostPosted: 12 Apr 2019, 19:05
I have had some luck with vinegar and water. Dump a jug of vinegar in and shake around or turn the tank periodically. Fill rest with water and let it sit. Take it to a carwash one town over at night and blast the heck out of it. Lol. Lacquer thinner eats the stuff good but will also take the paint off the outside. Last one I did was vinegar and carwash, then I put an inline fuel filter right off the tank.
PostPosted: 12 Apr 2019, 19:07
I like a handful of 1/4" nuts.
PostPosted: 12 Apr 2019, 19:09
Acetone to clean out a tank, gravel too sounds good! ADD a Racor fuel-water separator for good measure, cheap insurance!
#1) 1st tin rebuild, 18' Lund viewtopic.php?f=21&t=36583
#2) 25' Parker refurb from EMPTY hull http://www.classicparker.com/phpBB3/vie ... p?f=15&t=6
#3) 16' V-tin rebuild viewtopic.php?f=21&t=36465
#4 Procraft SV14
#5) 16' Starcraft entirely NEW Transom Skins viewtopic.php?f=3&t=37548
PostPosted: 15 Apr 2019, 14:27
That what I have done before with a motorcycle tank. Worked great.
I fish, therefore, I am.
1993 Starcraft SF 14 DLX side console with 25 hp Mercury 2 stroke
2003 Sylvan 2100 Profish walkthrough with 150 Mercury Saltwater and 6hp Mecury 4 stroke kicker
PostPosted: 15 Apr 2019, 18:28
Thanks for the ideas! Ended up using the pressure washer. Took the fuelcap off one end of the old metal tank and gauge off other end and it worked great.
Users browsing this forum: No registered users and 45 guests
cron
