whistler
I run two motors of different brands with two remote tanks. Since a water/fuel separator has two inlets and two outlets can I run them both through one separator? I suppose if they have a different size fuel hose I would need to get the separator to fit the larger diameter hose and reduce it down for the smaller one? Or would it be best since they are both 4 strokes. Can I use one gas can and hose to the separator and then run the two hoses with proper motor fittings to the different brand motors.
