Deadmeat
Maybe this question has been asked before but if it has I can't find it. I have a 25-hp Yamaha 2-stroke that I use pretty much all year. It's one of the advantages of living in the sunny south. So far at least I've been able to find 100% gasoline so the following question isn't as critical now as it will be when I have to go to ethanol. Right now I top off the gas tank after each trip in order to minimize condensation. It's usually no more than a couple gallons on a 6.5-gallon tank. I wonder if this will be the correct strategy after I begin to burn ethanol though. Topping off (often no more than a gallon) means that 4 or 5 gallons of old gasoline remain with the distinct possibility of going through phase separation and all the nasty things that can happen to the motor when it does. Would I be better to let the tank run down as low as possible before filling up or would it be better to keep topping off? For the most part I manage to get out on the boat at least once a week but there are times when I can go for several weeks without taking the boat out. I know I can use Sta-Bil or other gas treatments but I'm more interested in the topping off or running it dry strategy.
