Foot Oil Screw Stuck
Troutman3000
Gwinnett Georgia
I tried to change my foot oil thsi weekend but the screw will not loosen. I didnt want to strip the screw, but even with the biggest screwdriver it would slip. I used some wd-40 and other lubricants to help get it off but nothing worked. Anybody have some ideas before I take it to my motor guy?
Impact screwdriver
https://www.harborfreight.com/media/catalog/product/cache/1/image/370x/9df78eab33525d08d6e5fb8d27136e95/i/m/image_486.jpg
Awesome. I'll give that a try. I'll take a picture of the screw too so y'all can look at it and make sure it isnt stripped. I could always deepen the grove in it couldnt I?
Impact screwdriver will get it out fairly easy.
I don't have one so I use a ground down chisel that fits snugly in the slot and then attach a pair of vice grips near the handle to make it easy to turn. It usually removes them pretty easily.
I wouldn't bother trying to make the groove deeper. If you use the proper tools then it will come out easily. You can buy a new screw at any boat repair shop for a couple bucks.
I already have a screw and gasket in the way, I'll get that impact wrench on it this weekend. I hope it isnt cross threaded or anything like that.
crazymanme2 said:
Impact screwdriver
This.
Don't know anything about the quality of the Harbor Freight one, but the impact screwdriver in general is the absolute way to go.
bassboy1 said:
crazymanme2 said:
Impact screwdriver
This.
Thanks Dawson - how is school going this year?
I bought a really big screwdriver with a square shaft. I locked the motor down, attached the screwdriver to the slot, and put a crescent wrench on the shaft of the screwdriver. I had plenty of torque and it broke loose easily.
I have to agree impact screwdriver is the way to go. I had the same problem this winter and got mine out with my impact screwdriver pretty easily.
