Fuel Tank for 20hp?
PartsMan
Enid, OK
I have a Johnson 20hp 2 stroke on my 1655 Lowe.
All I have right now is the 3g tank from my old 9.9.
How much fuel will a 20 burn in a normal day of fishing?
Your 3 gallon tank is cutting it to close. I normally use 3 gallons per trip but sometimes up to 5 gallons. I am running a 25hp Evinrude.
It all depends on the body water size that your fishing if you will need a bigger tank. Either upgrade to a 6 gallon tank or take a 2 gallon reserve can with you.
I'm thinking the same thing :LOL2: I just put a 20 HP on my boat this year and wow, it's a hog compared to my 8.
I run 24 mile round trips often over the summer with my 14' jon with a rough tuned 20 horse johnson and go through about 5 gallons to do it. Loaded with beer and camp equipment and the wife the same trip takes about 7 gallons. It just depends on what you call a hard day I guess. A six gallon can under normal conditions works for me, I stack on another 6 gallons if its gonna be a long weekend of camping and fishing.
I have a 25 hp motor and have a 12 gal tank under a small deck up front.
A six with my three for reserve would probably work for everything I will do.
Still I may get a bigger tank just so I won't have to worry about fuel.
Plus if I want to make a long run I'll just fill it all the way up instead of hauling cans.
This is general rule of thumb.
0.1 gallon/hr per 1 hp at (WOT) wide open throttle
2 gallon/hr per 20hp at (WOT) wide open throttle
You will find the that you will get better gas consumption and mpg efficiency if you run you motor approximately 3/4 throttle.
Now with the above statement being said, older motors tend to be a little more gas thirsty than the newer fuel injected motors.
Get to know your motor and boat regarding fuel consumption. If you are embarking upon a distant trip, then bring an extra supply of fuel and oil.
Found this link regarding hp, rpm and fuel consumption....very interesting and informative.
https://www.marineenginedigest.com/specialreports/fuelflowchart.htm
Hope this helps. Get a 6 gallon tank and bring your 3 gallon as a back up. If you use up the 6 gallon tank then time to head back to the dock with the 3 gallon back.... :LOL2:
This is exactly what I don't want to happen.
Interrupting/cutting short a fishing trip cause I wasn't prepared.
Maybe it's the Boyscout in me. :)
I am kind of underpowered with this boat. May be running near full throttle quite a bit.
