FishingCop
I have a Johnson 9.9 kicker. I noticed dark brown oil coming out of the prop exhaust. Took it for repair and new prop bearings and seals were put in. This was done in October 2009. The motor was not run or started until last April (2010) when it was run for about 45 minutes a slow speed trolling. Now, when I started it last week (a year later), the same dark brown oil started coming out of the prop. Plus, there was oil leakage at the seams of the casing of the lower unit assembly.
Hummmmm, how could this happen? One guy said fishing line - well, actually, there was about 18" of line around the prop - but the front seal is fine - how could fishing line affect the rear seal?
My thought is that the shop that did the seals either didn't do the rear seal or screwed it up installing it??? 45 minutes of run time surely couldn't have done any damage to the rear seal causing the lower unit oil to leak into the prop exhaust??
Also, the oil leak at the seams tells me he didn't put in ne gaskets and/or seal them properly??
Any thoughts? Could it be a bent prop shaft or more likely a bad repair to begin with???
