Steering Linkage?
Have a question about your motor? All motor talk and questions go here.
bear7625
Steering Linkage?
Post by bear7625 » 22 Apr 2011, 15:17
I have a 1991 Johnson 15 HP outboard. I changed the steering system from the old cable & pulley to a Telflex rotary system. I'm looking for the linkage arm that connects to the motor. I need to know if there is a specific size or does one size fit all? I found some on eBay, but have no idea which one will work. New ones are to pricey for me. Any help would be greatly appriciated.
Thanks in advance.
TinBoatToo
Steering Linkage?
Post by TinBoatToo » 11 May 2011, 16:25
Check your local boat mechanic, Mine just gave me one off an old boat sitting out back for free!!. US Marine wanted $80 bucks!!!
Sam Underwood
1967 16' Starcraft Sportsman V
1957 Johnson 7.5hp
1990 Johnson 30hp
truckhuntfish
Steering Linkage?
Post by truckhuntfish » 16 May 2011, 11:56
this might sound funny buy it worked for me and already had one laying around but , do you know of anyone that races go karts around you ? If so get a steering arm from them , they have a ball joint type connection on each end that a bolt goes through. then i measured where halfway of steering cable , set motor in straight position then cut steering arm to length and bolted on.you can look at gokartracing.com for the part too they prob have it. i was in your spot when i thought of it and didnt want to spend so much on something so simple.
