willbarrow81
Well, to say it's running rough is a joke! The bulb assembley is new and Im adding an inline fuel filter tomorrow. Just a clear car one that I can toss when it gets to dirty, they are cheap and pretty good. Anyway when you take off the hood, above the hose connector there is the little tube with a small filter in it. When you squeese the hose it fills up, but also bubbles and leaks. The hose wont stay hard either, shoot I had to run it with the choke wide open and fast idle just to keep it going! Also the is just a very small amount of fuel in the tube, teeny! Im wondering can I bypass it since Im putting tje inline filter on? Or can I replace it with another inline filter in its place? (New fuel hose, 90' angle fitting, new filter) Thanks for the help! I took pics so It will seem obvious as to what I mean! Thanks, Will.
