Curious about my 1964 6hp johnson water temp..
willbarrow81
Black Mountain, North Carolina
Well, I guess you know I have a 6hp 1964 johnson seahorse; my question is two part, first how can you tell what is proper water-flow, and second when it's wot on the lake I can reach back and feel the pressure and water temp. Its flowing what seems to be ok, but the water is pretty warm after a couple mins. Should it heat up like that? Also should the water pressure increase with throttle? Thanks so much, Will!!!!
Try https://www.sschapterpsa.com/ramblings/OMC/OMC%20info.htm it will help you out.
