FishinsMyLife
As the title says, the lever on my Evinrude that locks the motor down (for reverse and transport) or allows it to kick up if I hit a stump is stuck down. It was working fine yesterday when I got on the water. Over the course of a couple hours of me moving the trim pin around, it decided to quit working.
This lever won't go up/forward.
I run a lot of shallow water, so I like to have it where it can kick up.
I just pulled the pin and locked the motor up with the L brackets and I can't for the life of me figure out why the lever won't go all the way forward :?: Everything looks to be in order under there as far as I can tell.
The rod with the red dot on it pulls the bar with the green dot on it, which would allow the motor to kick up. Problem the lever can't go all the way forward/up, meaning that rod can't pull that bar, so it stays locked down.
Anyone had a similar problem?
