So a new problem - 100 rpm flutter when on plane. 40hp Force
crkdltr
Post by crkdltr »
crkdltr
Post by crkdltr »
Loggerhead Mike
Post by Loggerhead Mike »
Absolutely, good diag
crkdltr
Post by crkdltr »
Lil' Blue Rude
Post by Lil' Blue Rude »
Did you set the timing with the motor in the water or did you just set it out of the water . Most outboards timing has to be set with the motor in water under a load to get the correct timing, same thing with jetting them.
16' 42" Blazer SS with a custom short shaft 60/40 Evinrude
