super_dork
Refer to the motor diagram in the attached link for the numbers listed by part names.
I picked up a 1986 Johnson 6HP this week and have been able to get it running. I've got it hooked up to the motor flusher and when it's running, it leaks oil and water around joint where the gearcase (#61) meets the extension (#68). I've never taken a the gearcase off but it looks like there are only a few bolts. I'm thinking that it just need to replace the gearcase cover gasket (#14). I'm assuming that I should drain the lower unit oil, then remove the gearcase and replace the gasket then put it all back together and fill with ouil again. Is there anything else that I need to do? Based on the problem description, does my diagnosis even seem right? This is my first go at this, so any help would be great.
Also, when it's running wide open it runs fine, but when I ease off the throttle it won't idle and just dies. Any suggestions on tuning it up? Every time I start messing with a carb, I seem to make it worse.
Thanks in advance!!
https://www.marineengine.com/parts/...=J6RCDE&manufacturer=Johnson§ion=Gearcase
Thanks in advance!!
