1992 Evinrude 15hp
Felony
South Florida
Hi everyone! This is my first post here, so go easy on me if you would :D I am, admittedly, a tinboat newb. I just picked up this motor, a 1992 Evinrude 15hp 2 stroke. It was, however, on a boat with a control setup. I am looking at purchasing a tiller setup for it, as well as some DIY's or anything that could be helpful on how to install it. In addition, I am looking for any information on the fuel pump. Supposedly, that is the only thing wrong with it. I am able to pull the pull start, and the motor seems to turn over fine. The prop also spins upon me spinning the big round thing on the top of the motor.(Sorry for my nubness) So maybe you kind fellows with a lot of patients could help a new boater on how to get started and what to do. If I can provide anyone with any further information, I will be happy to do so. :wink:
Look at the port side of the motor and see if a tiller arm was ever there. There should be a beveled type gear there.
There should be a shift lever on the starboard side of the motor for the remote control shift cable. That you can shift gears manually by just moving the shift lever. Make sure it's in neutral, usually middle position before trying to start motor.
Good luck.
There will be no bevelled gear on the side of the engine so don't bother looking for it unless you have an earlier model engine. Your model year had a simple cable operated throttle from the throttle handle. Give us your model number (from the side of the engine) and we can better help you.
Hey Pappy. Thanks for the info. You are right, I dont see any type of beveled gear like I see on the older motors. The model number is E15RENM. I am working on posting some pictures now.
Here are some more. Sorry for my poor picture taking.
Anyone have one of these tiller arms for sale? The motor is going to be taken to a friend of mine who is an outboard mechanic tomorrow or the next day and I will make sure to give you all a report!
if you go into marineengine.com look under boat motor parts, click on evinrude and install model#.it post all parts for the engine.here is the link:https://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1992&hp=15&model=E15RENM
No, the guy who I bought the motor from had it on his boat that I believe he purchased with the motor on it. He gave me everything he had. Does anyone know about how these fuel pumps function? They seem to have little to no moving parts, or so it looks like. The guy I bought it off of said either the gaskets or the pump itself were bad. He took it off the motor and I see the gaskets have a little bit of white corrosion. Do I need to just replace all the gaskets, or do I need to replace the entire pump?
ok you have a pull start motor according to the numbers on the model number.on marineengine you need rebuild kit #0393088.rebuild them because over time they deterioate.not sure of spelling.lol do not use anything but omc rebuild products .they last longer.i put two sierra kits in mine in a month.wasted money. get a 2x4 about 8 inches long.set fuel pump on it.from two locate 2 lower holes.drive a small nail into the holes.this will help make it still as you are taking apart and putting together.as you go take pics that way you know how it goes back together.its very easy.if you need directions pm me i can email you the directions on how to do it.go get yourself a omc service manual.helps alot.i will see if my manuals cover yours also.
Excellent. Thank you all for your insight. I will most certainly purchase the OMC Rebuild kit. Now, another few things I have noticed are missing/cut are these two items in this picture. From the video's I have been watching on youtube, item number 1 has something to do with the throttle I believe. It is a bar coming out from under the flywheel with a little ball fitting on the end of it that, from what I can tell, is supposed to be connected to a shaft that goes to the tiller arm. Is this a part of the tiller arm? Or do I need to purchase this additionally? Item number two is a long, cut piece of insulated wire wrapping with a few wires inside of it. What is it for? And where does it go? If anyone needs better pictures I can provide them.
So, I took my motor to a mechanic who is a friend of a friend of a friend yesterday. He told me I needed some black shift box (i forget the name) on the shifter side of the motor. The tiller arm, and the fuel pump gaskets replaced. Still LF parts so let me know if you have any! I need to actually check if the motor has compression before I go dumping alot of money into this thing as well.
So I have figured out that the insulated wire that I was speaking about in a prior post is the wire that goes to the emergency shutdown button. Does anyone have any closeup pictures of a 1992 Evinrude 15hp? Or a 9.9 for that matter? I am trying to figure out exactly everything that I am missing so I can start piecing it together.
I have the same motor................but mine is an Electric start.
Model E15ECEC
https://s454.photobucket.com/albums/qq263/Sapo60/?action=view&current=15HPEvinrude89.mp4
https://www.tinboats.net/forum/viewtopic.php?f=4&t=21376
