sixgun86
Picked up an Old two stroke Evinrude Tiller handle. The seller told me it wasn't pumping water and I have verified this after starting it up in a test tank. I've pulled the foot and the impeller, housing, & key on the drive shaft looked fine. Lined it up properly with tubing going to the power head and re-installed. Still not pumping. Getting nothing but exhaust.
When I removed the Drive shaft it came out of the lower unit. With a little convincing I was able to get it out of the power head and back into the foot to install the pump. Seems nothing is keeping it in place... Could this be why I'm not pumping? Any other ideas??
