Merc 7.5
TheCanOpener
Merc 7.5
Post by TheCanOpener »
Would a 7.5 Mercury be able to put a 14' tin on plane? The boat weighs about 175 lbs, and the people/equipment would weigh roughly 500 pounds. And in general, is this a decent motor? Not sure on the year, looks roughly 1970ish.
Thanks guys.
LOWEBIGJON
Merc 7.5
Post by LOWEBIGJON »
I doubt it..something that small is usually used for trolling..
LOWE 1852
Yamaha 25 HP ELH 2 stroke
Butthead
Merc 7.5
Post by Butthead »
A 2003 6hp longshaft 4-Stroke Tohatsu got my 1436 w/15" transom on plane. Boat weight=135lbs & gear and people weight=600lbs+. I would assume you should be okay with a 7.5hp as long as it's running right.
BtsNhoS
Merc 7.5
Post by BtsNhoS »
i use a 1986 7.5 on my 12ft and it works well, i have to use about half choke when i run full throttle though, sometimes it seems like i get a bit of cavitation since it is a long shaft but over all it works well.
jasper60103
Merc 7.5
Post by jasper60103 »
TheCanOpener wrote:Would a 7.5 Mercury be able to put a 14' tin on plane? The boat weighs about 175 lbs, and the people/equipment would weigh roughly 500 pounds. And in general, is this a decent motor? Not sure on the year, looks roughly 1970ish.
Thanks guys.
edit: just realized this is an old thread.
FYI. Here's a video of a 6hp planing a 14' tin...
2018 Tracker Grizzly 1648
